47 Users Online (46 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> crop region changes when placed on sheet
Fri, Jan 9, 2015 at 11:28:22 AM | crop region changes when placed on sheet
KYLIEBRAITHWAITE
i have been setting up sheets for my revit program.
i edited the crop region for the plans
i dragged each plan onto their sheet, but some plans are showing the plan crop region and an outer box/rectangle (see image attached)
what is this box/recatngle/region thingy?? and how do i edit/remove it?
kylie
Fri, Jan 9, 2015 at 3:33:08 PM | crop region changes when placed on sheet
SEdwards
That is your viewport with title line!
If you don't want the Crop Region visible you need to select the view and then in the properties window on the left scroll down till you get to "Extents" then unselect the Crop Region Visible box (I always have the annotation box checked). Apply and should look good. Then you can move your title line when the viewport is not highlighted hover over the text in the title block and then the hold down the right mouse button and move where you want.
Hope that helps.
Crop Regions Disappear When I Assign a View Template
Sun, Apr 22, 2018 at 11:04:21 PM
dimensions on plot sheet with reference to whats inside a view crop region
Wed, Apr 18, 2007 at 10:18:34 PM
Crop region not affecting grid lines
Tue, Oct 19, 2010 at 4:00:30 PM
Revit 2009-Crop Region and Show Crop Buttons Disappeared
Thu, Jun 25, 2009 at 2:09:48 PM
Is it crop region or something else? Splitting up a drawing correctly matchline
Tue, Oct 10, 2006 at 2:51:00 PM
Page generation time: 0.5109
