79 Users Online (78 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Hatch Question
Fri, Jan 9, 2015 at 10:22:50 AM | Hatch Question
KraigZ
I am using a hatch to denote wall height on my exterior foundation walls. The only issue I am having is showing blockouts at the Doorways. The border of the hatch is shown as a solid line and i need it to be hidden in order to show the blockout. Below are two images, one of how I want the Blockouts to look, and the other with the Color is where I am Having issues. Is ther any way to fix or change this? If I could make the border of my hatch hidden, I could dray in solid line where nessisary.
Thank you for your time,
KraigZ
Fri, Jan 9, 2015 at 10:31:31 AM | Hatch Question
If by blockouts, you mean the wall is held down for an opening, then is the opening modeled? If you cut through the wall, it will be hatched.  If you cut through the opening it will not be.
Maybe you need a plan region to have a different view cut elevation here.
Wall hatch question
Tue, Oct 17, 2006 at 11:25:00 AM
HATCH 22- REVIT MODEL HATCH
Fri, May 8, 2015 at 3:01:05 AM
Hatch pattern on a wall
Thu, Mar 29, 2012 at 9:00:22 AM
Sloped Hatch Pattern
Fri, Oct 2, 2009 at 1:57:20 PM
Hatch 22- Curve Pattern
Wed, May 30, 2018 at 4:07:08 PM
Page generation time: 0.7768
