58 Users Online (55 Members):
Forums >> Revit Structure >> Technical Support >> Can't dimension to center of a circle? NewtoRevit
i'm creating a family for a base plate with 4 bolt holes but i can't dimension the center of the bolt holes?
It would be better to have located the holes by using reference planes and dimentioning to those.
My previous answer was based on dimentioning in the family. If you want to dimension in the project, you will have to make those reference lines "stron reference".
BTW _ for annotative circles, you can turn on the center under properties.
thank you that really helps!
Constraining a circle centered between two reference planes |
Fri, Apr 7, 2017 at 8:22:50 AM
Dimension for curve line |
Wed, Mar 21, 2007 at 7:11:01 AM
Dimension center line of foundation |
Thu, Oct 4, 2007 at 7:40:43 AM
dimensioning to a center mark of an arc |
Wed, Jul 5, 2023 at 3:13:09 PM
orthogonal dimensions to radial dimension center point |
Fri, May 14, 2010 at 3:22:32 PM
Members: | 2017250 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
