28 Users Online (26 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Tops of the walls applied to mass looks horrible
Sun, Jan 4, 2015 at 12:34:17 PM | Tops of the walls applied to mass looks horrible
ViliusB
Hi, I'm trying to apply walls to mass, but the outcome is horrible. Tops of the walls does not connect together. Maybe someone could tell me how to fix it, so that the top of the walls would follow the shape of the mass?
Mon, Jan 5, 2015 at 10:31:02 AM | Tops of the walls applied to mass looks horrible
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Maybe its just your image but these don't look like complicated walls, why are you using a mass instead of just a normal wall?
Mon, Jan 5, 2015 at 10:45:48 AM | Tops of the walls applied to mass looks horrible
A agree with teafoe.   Always use normal walls whever possible but in this case, I believe the wall causing your problems appears to be leaning - correct?
Walls by face are typical Revit walls ....APPLIED BY FACE.... Period!  So in this case, the wall is tilted and the top is therefore tilted.   If you want the top to be anything different than perpindicular to the face, then you will have to modify it.
walls disassociated with mass - can't update walls
Fri, Nov 2, 2012 at 10:51:19 AM
extruded generic model and mass floors (2012)
Fri, Sep 21, 2018 at 3:36:04 AM
how to fix distorted hatch pattern on wall?
Fri, Jan 18, 2013 at 6:18:30 PM
Materials on masses are being applied to all my masses...HELP!?
Sat, Mar 14, 2009 at 1:58:59 PM
In place counter tops.
Tue, Dec 9, 2008 at 10:34:39 PM
Page generation time: 5.3439
