68 Users Online (65 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> BOP Relative to Sloped Soffit Above
Fri, Jan 2, 2015 at 1:51:31 PM | BOP Relative to Sloped Soffit Above
koolair
4.5 Stars: 2 Votes
Hi guys, long time no ask a million questions...
Quick tip followed by a question.
I am setting my Bottom of Pipe elevations for drainage and other pipes. My foreman wants to see BOP relative to soffit above.
If it's flat - no problems. I go to an elevation view, copy one of my elevation lines, align to soffit, click "lock". Rename level to "P4 Soffit"
I go to my BOP tag and on the properties browser you see a field called "Relative Base".
I have it set to "Current Level". It's a drop box so all I have to do now is set it to the name of the new elevation, namely, "P4 Soffit".
Voila! Now my foreman can walk with a tape and mark off his hangers at the appropriate heights.
Now here's my problem. The P4 slab tilts upwards in some areas.
Is there any way I could "program/hack/reverse engineer/etc" the BOP tag so it reads from a "Relative Base" that is sloped?
All the best you guys in the New Year. Rock on...
Mon, Jan 5, 2015 at 7:38:53 AM | BOP Relative to Sloped Soffit Above
3.5 Stars: 395 Votes
I don't see a way to do what you want.
Dimensions have to be to a real reference.   A point in space has no references.   Where is it?
Seems like your foreman has never used a laser level.
BOP Tags for 2nd floor and above
Thu, May 21, 2009 at 4:28:57 PM
BOP Tag for 2nd floor and above
Wed, May 20, 2009 at 10:03:04 AM
Recessed lighting in soffit?
Mon, Nov 15, 2010 at 10:32:36 AM
Soffit - Curved Soffit
Thu, Feb 14, 2013 at 8:57:20 AM
Slanted wall in section & sloped ceilings
Wed, Feb 18, 2009 at 2:10:44 PM
Page generation time: 0.3774
