79 Users Online (78 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Revit Project Management >> dashed lines above cut plane
Thu, Jan 1, 2015 at 3:50:56 PM | dashed lines above cut plane
clickster
clickster Avatar
I have created a family (a structural diagonal brace), which I would like to appear in plan with dashed lines above the cut plane.... similar to the way that stair treads appear dashed. Does anyone know how this can be done?
Fill what is empty. Empty what is full. Scratch what itches.
Fri, Jan 2, 2015 at 11:05:36 AM | dashed lines above cut plane
zsmith3
What kind of family template did you start with to construct the family? Structural framing?
Fri, Jan 2, 2015 at 1:29:41 PM | dashed lines above cut plane
clickster
clickster Avatar
I used the generic template
Fri, Jan 2, 2015 at 2:28:19 PM | dashed lines above cut plane
zsmith3
So the family is a static / nonparametric sloped extrusion?
The simplest way would be to draw dashed model lines on the reference plane (in the family) that are aligned to the outside flanges of the sloping member above. The extrusion would mask the dashed lines when displayed in plan, but not above the cut plane. That isn't a very 'bim' way to do things, but will accomplish what you are asking I think.
Disappearing dashed lines?
Tue, Feb 21, 2017 at 2:16:49 PM
Very basic question about displaying lines
Mon, Apr 28, 2008 at 11:35:54 AM
Dashed lines in families are showing as solid lines in project
Thu, May 10, 2012 at 8:38:49 AM
objects above - dashed line
Fri, Oct 21, 2005 at 4:43:05 PM
Elevation's primary cut plane disappered and no grips
Tue, Apr 10, 2012 at 11:49:00 AM
Page generation time: 2.1158
