91 Users Online (90 Members):
Forums >> Revit Building >> Technical Support >> Changing default from Revit 2014 to Revit 2015
Does anyone know how to make the latest version of Revit the default program in Windows 8.1? I have both Revit 2015 and 2014 installed. If I double click any Revit file, my computer chooses 2014 to open it. If I hadn't uninstalled Revit 2013, it would be choosing that as the default program. It's done this with each new version of Revit and it drives me crazy!
![5 Stars: 5 Votes](/images/stars_5.gif) |
Keep in mind that Revit is not a backward compatible program.
You should change your way of openning the drawings, never open the Revit drawings through Windows Explorer folders/files.
Always open the proper Revit version first, then open the drawings from the program.
If you want to work on 2015 version, and opened a drawing done in 2014 accidentally, it will give you a chance to close that drawing without save it, otherwise it will make other people in your office work on 2014 unable to open it.
The thread below might give you more ideas.
http://www.revitcity.com/forums.php?action=viewthread&thread_id=33412
Opening a 2015 drawing in Revit 2014 |
Tue, Jul 29, 2014 at 9:11:58 AM
Revit 2015 Ultimate / Standard compatibility? |
Wed, Oct 1, 2014 at 6:10:21 PM
Revit 2015 Install Error |
Tue, May 20, 2014 at 9:24:55 AM
Point Cloud in Revit 2014 no longer working in Revit 2015 |
Fri, May 15, 2015 at 3:23:06 AM
Any way of changing default view of a family thumbnail? |
Thu, Nov 7, 2013 at 8:07:04 AM
Members: | 2017187 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
