38 Users Online (37 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> Oblique Symbolic lines
Tue, Dec 30, 2014 at 6:11:23 PM | Oblique Symbolic lines
clickster
clickster Avatar
I created a curtain panel with symbolic dashed lines to represent an operable window in elevation. The lines are showing up fine in 'straight-on' elevations, but they disappear in oblique elevation views. Is there any way to get them to show up?
Fill what is empty. Empty what is full. Scratch what itches.
Tue, Dec 30, 2014 at 10:12:43 PM | Oblique Symbolic lines
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Select your lines and click 'convert lines' on the ribbon.
Wed, Dec 31, 2014 at 7:22:19 AM | Oblique Symbolic lines
3.5 Stars: 400 Votes
Symbollic lines are 2D and thus, only show up in views normal to how they were created.  pijpiwo is having you convert them to model lines in the family editor.  I have seen instances where the convert lines is not available.  When it does work, the model line is placed on a work plane.  You need to look at what plane that is because your model objects may hide it.
Edited on: Wed, Dec 31, 2014 at 7:22:48 AM
Thu, Jan 1, 2015 at 3:47:42 PM | Oblique Symbolic lines
clickster
clickster Avatar
thank you kindly
SYMBOLIC LINES
Thu, Aug 16, 2012 at 7:01:09 AM
Symbolic Lines and Model Lines
Wed, Mar 22, 2006 at 12:52:17 PM
symbolic lines
Thu, Jul 13, 2006 at 8:15:41 PM
Symbolic lines
Tue, Dec 26, 2006 at 2:24:22 AM
Windows above the Cutplane and Symbolic Lines (Revit2010)
Wed, Jul 14, 2010 at 7:35:42 AM
Page generation time: 0.5726
