59 Users Online (56 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Color Scheme- Fill Pattern- Lineweight
Tue, Dec 30, 2014 at 9:06:23 AM | Color Scheme- Fill Pattern- Lineweight
HKicsak
Is there a way to increase the lineweight of one particular fill pattern in a color scheme?
I only need one value to show darker/thicker and cannot find a work around. Any help is appreciated!
Using Revit2014, dragging the rest of the company with me from AutoCAD2008. When will the whining stop?
Tue, Dec 30, 2014 at 10:12:04 AM | Color Scheme- Fill Pattern- Lineweight
We do not yet have control over hatch pattern pen weights.   BUT you can over-ride in view and half-tone a hatch - so why not lighter in one instance rather than heavier?
Wed, Dec 31, 2014 at 11:38:58 AM | Color Scheme- Fill Pattern- Lineweight
mertens3d
5 Stars: 2 Votes
Or create a similar hatch pattern with double lines such that when printed they appear as one thick line.
Edited on: Wed, Dec 31, 2014 at 11:40:09 AM
...gregory
http://mertens3d.com
my Revit - Bugs/ Issues/ Requests
Fri, Mar 13, 2015 at 2:50:40 PM | Color Scheme- Fill Pattern- Lineweight
evelhalo
All of the fill patterns are associated with the same line weight (although a cut pattern is associated with the material). It takes a little more time than using the standard cut patterns but if you put a fill region over the area you are trying to hatch it is associated with pen 5:
manage>additional settings>lineweights>model line weights> "5"
you can adjust this per your view scale in this menu
color scheme/fill pattern
Mon, Jul 9, 2012 at 4:56:37 AM
Fill Pattern Lineweight
Thu, Oct 12, 2006 at 8:15:53 AM
MEDIUM SCALE FILL COLOR AND PATTERN
Tue, Sep 11, 2012 at 7:06:13 AM
color scheme disappear
Fri, Sep 24, 2010 at 7:49:23 PM
color fill weird fill
Thu, Oct 8, 2009 at 2:55:21 PM
Page generation time: 1.6946
