52 Users Online (51 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Black background on text (imported DWG)
Tue, Dec 23, 2014 at 3:15:04 PM | Black background on text (imported DWG)
TruckBoy
I'm having a weird issue with imported AutoCAD drawings into Revit 2013. I get the background on the text fields as solid black. This is a change that happened after installing Revit Architecture 2015, prior to that all the text in the imported DWG was fine. I can't find an override for the text backgrounds in either object styles or VG settings. Any insight?
Wed, Dec 24, 2014 at 7:15:17 AM | Black background on text (imported DWG)
I've not seen this happen in this direction - only export to CAD.
Do you have your 2015 updates installed?   << That is a must!
Did you set the import to invert the colors when importing?
Thu, Feb 18, 2016 at 8:38:48 AM | Black background on text (imported DWG)
rozicki
5 Stars: 2 Votes
Restart your computer.  The issue is probably not revit related, other users on the same file don't have the same problem.
Edited on: Thu, Feb 18, 2016 at 9:02:52 AM
Black background in text box
Fri, Feb 19, 2016 at 7:23:03 AM
Annotations accidentally snapped into linked dwg (Imported categories)
Tue, Jul 9, 2013 at 5:53:12 AM
Decal Background is Black
Wed, May 1, 2019 at 5:57:18 AM
imported images black when zoomed in
Fri, Sep 26, 2014 at 9:01:53 AM
White text on Black background
Thu, Aug 9, 2007 at 3:05:06 PM
Page generation time: 1.2483
