62 Users Online (61 Members):
Forums >> Revit Building >> Technical Support >> Family object: creating specific properties
Hello,
I'm modeling my first family object (that Ill share with you guys latter): window.
The question is: is it possible to add a parameter or sth to a family object that allows to hide or show some parts of an object later through type properteis (in scene). (for example check/uncheck box)
I want my window to be with interior sill. But if I need a floor-ceiling window, in that case I dont need interior sill. So what I want to do is to add a ability to "turn off/on" a sill.
Sorry for, maybe, bad english and I hope I explained everything clear enough
Thank you in advance for your help...
Yes add a visibility parameter that is type based.
put object ID field in the properties palette in the family editor |
Mon, Oct 17, 2011 at 12:02:32 PM
No ''materials'' properties on my object |
Fri, Jun 18, 2010 at 11:57:28 AM
How to change material properties of a mass |
Tue, Nov 18, 2008 at 11:46:25 PM
how to know the material used in a specific object? |
Mon, May 9, 2011 at 1:14:23 PM
Generic models in DWF viewer (Object properties) |
Tue, May 8, 2012 at 11:08:33 AM
Members: | 2022277 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
