75 Users Online (73 Members):
Forums >> Revit Building >> Technical Support >> guardrails
0 Posts No Rating |
I would like to use a top and bottom rail of 1" square steel tubing. However, in the rail selection the smallest is 2". I suppose because the program thinks it is a stair rail requiring a minimum size. Is there a solution?
integrity
A rail is just a profile. You can create your own, any shape you want.
0 Posts No Rating |
And how do I do this and then get it into the selection dialog?
Which one are you trying to get - rail, top rail, or handrail?
0 Posts No Rating |
I'm using Revit2011 and don't have that dialog. Is that the problem?
No problem.
Use Profile-Rail.rft template (or Profile.rft if 2011 doesn’t have one and change profile usage to railing in properties), draw a profile you want and load it to you project. In the project, select the rail->type properties->edit (rail structure), your custom profile should be listed under profile heading.
Elevation Transparency |
Wed, Sep 12, 2007 at 2:41:19 PM
Glass Guardrails/handrails |
Mon, Jul 31, 2006 at 11:39:18 AM
normal bed with variable height? |
Wed, Jan 11, 2012 at 5:03:28 AM
Connection Points |
Mon, Apr 13, 2015 at 11:02:16 AM
Varying Baluster Heights |
Thu, Jun 12, 2014 at 2:21:56 PM
Members: | 2057523 | Objects: | 23074 | Forum Posts: | 152250 | Job Listings: | 3 |
