58 Users Online (57 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> Imperial Projects and Families help needed
Tue, Dec 9, 2014 at 12:39:04 PM | Imperial Projects and Families help needed
turbostar
Hi guys,
Why is it everytime I open a new project or family they appear  only in metric. I tried searching my Revit 2014 for Imperial and cant find it. Can someone tell me the procedure into getting Imperial projects and families???
Tue, Dec 9, 2014 at 12:49:37 PM | Imperial Projects and Families help needed
You are using a template with metric settings.   Use a different template or alter the one you are using.
Tue, Dec 9, 2014 at 12:58:06 PM | Imperial Projects and Families help needed
turbostar
Change templates? Besides since I work in Imperial all the time, Id like to automatically start out with Imperial.
(I dont have the CD mines is directly downloaded from Autodesk)
Tue, Dec 9, 2014 at 1:04:12 PM | Imperial Projects and Families help needed
perial; template is set to imperial.   Someone has altered your template.   Change it back.   Open the template (not a new project) and change the appropriate settings.   Since there are multiple places that units are set, you will have to ferret out all of them.   The main one is project units.
Tue, Dec 9, 2014 at 1:21:08 PM | Imperial Projects and Families help needed
turbostar
Isnt there a way where I can just load Imperial templates???
Tue, Dec 9, 2014 at 1:27:10 PM | Imperial Projects and Families help needed
You can reload the program.
But you should really understand how you changed wht you had and how to fix it so that you don't do it again.  You can read all about the project template in your help.
Tue, Dec 9, 2014 at 2:19:36 PM | Imperial Projects and Families help needed
turbostar
I probably didnt explain myself properly because I was in a rush and multi tasking at the same time.
The problem is whenever  i decide to start a new project my settings and units are all in metric. Even if I decide to make a new family all my templates are in metric. I dont get any option to select imperial templates.Even the components are all in metric.
I know i can type UN and change the units in there, but I dont want to do that everytime. Id like to have everything in Imperial units right off the bat.
Tue, Dec 9, 2014 at 2:27:19 PM | Imperial Projects and Families help needed
There are two libraries installed with Revit.   A metric and an imperial.  You are obviously using the wrong library because your pointers were set wrong when Revit was installed or you changed them.  The pointer to the library is set for multiple items under the Revit R dropdown / options.
Read this in your HELP:
http://help.autodesk.com/view/RVT/2014/ENU/?caas=caas/sfdcarticles/sfdcarticles/Cant-find-the-Library.html
Tue, Dec 9, 2014 at 3:08:57 PM | Imperial Projects and Families help needed
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
It sounds like the software doesn't have any of the Imperial content installed. Period, end of story. You can contact your Autodesk reseller and they can get it to you or you can repair your insstall from your autodesk subscription. Or reinstall the entire program and just make sure you select the imperial content as part of the install.
When you install REVIT under Configuration it gives you a whole assortment of installation aspects above and beyond just imperial content.
Once you have the Imperial content installed you can set any number of favorite templates to start with, in the REVIT 'Options' dialog box as well as your prefered folder for families and family templates.
Edited on: Tue, Dec 9, 2014 at 3:16:02 PM
Tue, Dec 9, 2014 at 10:55:55 PM | Imperial Projects and Families help needed
turbostar
Thanks I had to reinstall the whole thing because for some reason I couldnt find the Revit Icon in the control panel to uninstall it. After reinstalling it, I went to uninstall to add the missing content. After all that my Imperial library was there!
Thank you WWHub + dgcad for your help!!!
Just out of curiousity I'm able to find the architectural template in metric, is there one in imperial??? (I use default)
Wed, Dec 10, 2014 at 12:53:43 PM | Imperial Projects and Families help needed
#11
Your project templates are also in your library ... you may have to go up a level or more from the family library.
Change imperial to metric
Wed, Mar 11, 2009 at 9:20:24 AM
IMPERIAL LIBRARY
Mon, Apr 7, 2008 at 4:54:49 AM
Imperial metric question RAC2009
Fri, Jan 9, 2009 at 11:35:51 AM
update imperial library files
Mon, Mar 15, 2010 at 3:05:40 PM
Default Folder
Wed, Feb 13, 2013 at 6:07:53 AM
Page generation time: 1.2489
