48 Users Online (47 Members):
Forums >> Revit Building >> Technical Support >> Type Catalog
2 Posts No Rating |
I am creating the text file for my type catalog and have had no problems filling in the parameters.
When a family has 2 or more types, is there a way to list in the catalog which type it should use.
For example:
I have a family for web penetrations in Wide Flange beams. There are the usual beam parameters which are listed in the type catalog. Additionally, in the family I have two types: SQ (for square openings, H_opening = W_opening) and RECT (for rectangule openings, H_opening independent of W_opening). I'd like to be able to select the beam size (i.e. W12x50) along with the opening type (SQ or RECT).
Based on the help file section "Creating a Type Catalog" it would seem like I could have two entries:
W12x50 SQ
W12x50 RECT
How do I relate an entry in the type catalog to a specific type in the family?
adding parameters to a family with a type catalog |
Thu, Feb 19, 2009 at 11:10:20 AM
Revit 2010 Yes/No in type catalog |
Mon, Mar 29, 2010 at 9:14:02 AM
type catalog |
Fri, Apr 8, 2005 at 2:35:30 PM
Family Type Catalog - Model Parameter will not take |
Tue, Sep 1, 2009 at 8:01:06 AM
Uploading type catalog file directories with RFA files |
Fri, May 14, 2004 at 12:49:21 AM
Members: | 2022380 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
