45 Users Online (43 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Reporting Parameter - Height/Elevation - Face based family
Thu, Dec 4, 2014 at 9:26:09 AM | Reporting Parameter - Height/Elevation - Face based family
blitz355
Hello,
I have a face based family in Electrical Fixtures (which I have attached below) for a Duplex Receptacle. The goal is to be able to drive the elevation of the receptacle from either the instance properties or the electrical utility tag that we use for our MEP drawings. This way everything updates and provides a user friendly experience.
I have tried to add dimensions to the host, which I assume is the "face" that the extrusions that make up my receptacle sits inside. However, I'm unable to dimension to any of these lines... Is this a limitation to the type of family being used? (face based?)
Your help is appreciated.
Can't control non-elevation height of light sconce (wall-based family)
Tue, Jan 4, 2022 at 3:42:00 PM
Tagging Default Elevation Parameter for Face-Based Families
Wed, Aug 13, 2014 at 8:57:26 AM
changing type of a family from wall based to face based
Wed, Mar 3, 2010 at 8:24:37 PM
How would you modify a family from face-based or hosted to one that is not?
Mon, Sep 26, 2011 at 8:39:50 AM
Wall Based Plumbing Fixtures.. Elevation parameter.. help please!
Thu, Oct 2, 2008 at 12:08:49 PM
Page generation time: 2.3455
