28 Users Online (27 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> problems with a grid line title in relation to edge of viewport
Tue, Dec 2, 2014 at 2:48:14 PM | problems with a grid line title in relation to edge of viewport
kenyhel
I have a grid file within my drawing which is an REVIT LINKED file within the sheet.
As you can see I have a problem relating to the fact that the grid line and text falls outside of the view port and indeed the sheet.
When I try and amend the size of the viewport what I have discovered is that there is some setting which sets a distance from the edge of the view port and the title of the grid line.
Can somebody please tell me how you control the relationship between the title of the grid line and the edge of the viewport?  What I am trying to achieve is a minimum distance between the edge of the drawing and the title of the grid line.
http://screencast.com/t/xuuNtvrpgiL
Thu, Dec 4, 2014 at 3:34:12 PM | problems with a grid line title in relation to edge of viewport
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I think most people copy / monitor the grids and levels into the local file and then control the grid / level endpoints locally. Then you can use the regular 3D / 2D control of each endpoint per view to tighten it up to fit on the sheet.
You may also want to watch the free video series here Daryl's Picks called " Datums, Views, Crop Regions, Scope Boxes and Reference Planes"
viewport title with line question
Tue, Jul 8, 2008 at 11:38:17 PM
Viewport title locked. How to unlock?
Tue, Sep 30, 2008 at 3:20:48 PM
Stretch/move text location in Viewport Title
Wed, Sep 12, 2018 at 4:06:35 PM
Viewport Title Line Weight
Wed, Mar 12, 2008 at 8:14:52 PM
How can I Modify the Viewport title?
Tue, Jun 19, 2007 at 7:28:09 AM
Page generation time: 3.4860
