Using Revit 2015, I'm making a pdf of a perspective view (see attached) and get some additional lines around the eleptical, large, ceiling based family. It doesn't have anything to do with the connection to the ceiling, as I've separated the family from the ceiling, but in every perspective it adds the additional spiral lines. I've made the perspective with the family hidden and the lines aren't there. In short, the problem is in the family. I tried to make it as an in-place family with the same results. I adjusted the perspective and pulled new views, all with the same results.
Finally, I have another file, using the same family but smaller, in which I've modeled another scheme in the same space, and I don't have the problem.
Any suggestions?
Edit: I realize it wasn't clear - the lines only show up when I make a pdf. They're not there in model.
Edit 2: I changed the size of the family to 95% of it's original size (99% & 96% didn't work). This seemed to appease the beast. Though, it still measures smaller than what we need. I have this work around for now, but would still like to hear anyone's thoughts and ideas regarding the initial problem.
Kind regards,
Ben
Edited on: Wed, Dec 3, 2014 at 9:17:28 AM
Edited on: Thu, Dec 4, 2014 at 12:17:55 PM
