101 Users Online (100 Members):
Forums >> Revit Structure >> Technical Support >> Offset Level of Steel Beams - Start/End or Z
I wonder if anyone can clarify, we are doing a number of steel framed buildings and have noticed that some people offset their beams using the start/end Level offset and some are using the z offset value.
Although i appreciate it may not matter (except for maybe analytical) but can anyone tell me what method they use or which is correct (if there is a correct way).
Many Thanks
![teafoe5 Avatar](user_avatar/204239.jpg)
![4 Stars: 47 Votes](/images/stars_4.gif) |
The Z value offset will offset the entire beam, the start/end level offset can be used to control a sloped beam. either works, one just needs input in 2 places rather than 1
shell beams |
Fri, Aug 7, 2009 at 10:17:13 AM
Beam to Column ???? |
Fri, Jun 11, 2010 at 5:05:06 PM
Top of Steel Level for rotated beams |
Wed, Sep 21, 2016 at 2:03:21 PM
Beam system, cant offset? |
Fri, Feb 13, 2009 at 8:16:03 AM
Beam start/end extension |
Fri, Feb 12, 2010 at 10:59:48 AM
Members: | 2017166 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
