Forums >> Revit Building >> Technical Support >> How can you place a ceiling in a floor if theyre both 3D elements???
1 Posts No Rating |
Hi guys,
I'm having problems understanding where to place ceilings. I understand floors and ceilings are both 3D elements.
So how can you place a ceiling in a floor if theyre both 3D elements???
In a project im working on, my 2nd Floor is 9-3/8” thick and placed 8’-10” above the 1st floor. My 2nd floor is composed of:
- Finish - Wood glue laminated
- Structure: Wood sheathing
- Structure: Wood joist
- Structure: Wood furring
- Structure: Gympsum wall board
My Ceiling = 1-1/4" and is composed of:
- Structure: wood furring
So where does my ceiling go, at the same height of at where I placed my wood furring????
-Using Revit 2014
looks like some duplication there.
delete items 4 and 5 of floor
and leave items 1 and 2 of ceiling.
alternatively, delete only item 5 of your floor and only have the gypsum as your ceiling, spaced accordingly.
cheers
geoff
1 Posts No Rating |
That make sense, just wondering is that the best way to do floors and ceilings?
Does anybody have any other methods they use to connect floors and ceilings?
Thanks geoff
What do you mean by connect?
mansell gave you the normal / best process.
1 Posts No Rating |
Great, I was just wondering!
Reflected Ceiling Plan not showing revit link elements |
Tue, Dec 7, 2021 at 6:55:56 AM
Nothing Shows |
Thu, Sep 22, 2016 at 7:39:57 PM
First floor slab or ground floor ceiling? |
Fri, Aug 30, 2013 at 7:41:03 AM
Revit 2015 join wall to underside of floor and ceiling issue |
Wed, Mar 2, 2016 at 2:59:03 PM
FLOOR / CEILING PROB WITH HOSTING LIGHT FITTINGS |
Thu, Dec 15, 2005 at 10:30:38 PM
Members: | 2104901 | Objects: | 23178 | Forum Posts: | 152306 | Job Listings: | 3 |
