Forums >> Revit Building >> Technical Support >> Revit doesn't show Autocad isometric drawings
Hi All,
I'm trying to creating an isometric plumbing plan, using Autocad Architecuture 2013. After creating the plan, I saved it
in the SW Isometric view. I even typed the command " Proxygraphics" to turn it on(1). Then I imported that DWG file, using
Revit Architecture 2013, into a drafting view. But Revit just displayed a flat 2d floor plan. Is there a way to make Revit to display Autocad isometric views.
Thanks
Andy
You imported a 3D view into a 2D view - of course it will be 2D.
If you import CAD into "this view only" it will be 2D.
If you may change this, then I would link instead of import. If you link it into a workset that is normally off and place the view off in space, you might be able to get what you want.
I'm pretty shure you can do all of this directly in Revit so why CAD?
Thanks. I tried to link as you suggested , but it was still flat lines. So I had to print it from Autocad then used copy&paste the plan in Blue Beam Revu( or any PDF). In order to create 3d lines, we need to pick the work plane, or UCS in Autocad. But when I activated the drafting view in Revit, there is no work plane to be picked, unless Autodesk had added the function in its 2015 version, which I don't have.
How to make Revit elevations look like AutoCad Drawings |
Tue, Nov 27, 2007 at 9:11:37 AM
Isometric Views & Scale |
Fri, Aug 20, 2010 at 11:18:08 AM
Isometric Drawing |
Mon, Jun 2, 2008 at 9:48:03 AM
Why doesn't reivt have the simple autocad commands that we know and love. [ 1 2 ] |
Thu, May 7, 2009 at 1:22:39 PM
15
Isometric Dimensions in Drafting Views (details) |
Fri, Sep 28, 2012 at 3:13:09 PM
Members: | 2098578 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
