135 Users Online (132 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> Newbies >> attaching equipment to walls
Fri, Nov 21, 2014 at 7:38:22 AM | attaching equipment to walls
fifthtexas
i am a new user to revit, i have been inserting different families into a new project, but i find that sometimes i can not place various equipment to where i want, i have a wall and i would like to place some wall mouted items, say a distribution board
i find that sometimes it works and sometimes it dosent, i select my family place it into the model, and i can place it on a wall, set height, but there are walls i have in my project where i want them and it wont let me, i get a no error symbol
why can i not do this, why will they mount ok on some walls and not others, i have a plant room, i can place on one wall but not the other, what am i doing wrong.
Fri, Nov 21, 2014 at 7:58:37 AM | attaching equipment to walls
Not enough information.
Is this a wall based family, a face based family, a workplane based or what?
What is the difference in these walls?  Did you create them?  Are they in a link?
Fri, Nov 21, 2014 at 8:29:28 AM | attaching equipment to walls
fifthtexas
hi
sorry, yes this is a wall based family. that is in list of families you get in revit, a distribution board
and i am using a linked file. do i have to set a workplane?
it will attach to some walls but not others
many thanks for the help
Fri, Nov 21, 2014 at 8:43:24 AM | attaching equipment to walls
Obviously you are not understanding my question and therefore you miss the answer.
Families can be hosted in several ways.  A face based family acts pretty much the same as a wall based family except it can be placed on any face whereas a wall based will only go on walls.   The panels I see in the library are all faced based.   But you say this is a wall based family.
Wall based families can only be hosted to walls that are in YOUR model - walls that you own.   A linked wall will not host a wall based family.   This is why MEP users now prefers to have face based families.
I asked you what the difference between these walls was.   I will bet you that the wall that does host this item is actually in your model.   It may have been copy-monitored in when the link was created or added afterwards.   When you click on the walls one at a time, the linked wall's properties will be ghosted, the model wall's properties will not be ghosted.
Mon, Nov 24, 2014 at 2:28:42 AM | attaching equipment to walls
fifthtexas
thanks for explaining to me differences, i am new to revit so getting confused
yes the wll in question is linked from arch model, so how can i get a family placed onto a linked wall?
what is the method, i have linked in arch model, using a plantroom, want to but various equipment onto linked in wallshow do i do it?
much appreciated
Mon, Nov 24, 2014 at 8:16:00 AM | attaching equipment to walls
Copy/monitor the architect's walls.   Then you will own those copies and you can turn off the architect's walls.   READ the HELP on the copy/monitor process.
Mon, Nov 24, 2014 at 8:39:00 AM | attaching equipment to walls
It might be better to find a face based family.....
Attaching Rails to walls
Thu, Aug 13, 2009 at 12:59:43 PM
Attaching curtain walls to multiple roofs
Mon, Nov 5, 2012 at 2:19:45 PM
Equipment Schedules
Tue, Jun 17, 2008 at 11:39:13 AM
Mechanical Equipment pipe connectors...
Tue, Nov 18, 2008 at 11:21:29 AM
Medical Equipment
Mon, Apr 30, 2007 at 10:12:26 AM
Page generation time: 1.9917
