34 Users Online (32 Members):
Forums >> Revit Building >> Technical Support >> MATERIAL TAKE OFF FOR A ROOM
0 Posts No Rating |
Hi,
I am using Revit 2015 and need to get the area off the walls from each room separately. Is the good and more appropriate way to do it than drawing a wall, thean another wall for example gypsum as a cover for each room?
Anna
No easy way to do this with Revit. Use the room dimensions.
0 Posts No Rating |
Thank you for the respond. Could you explain a bit how it can be done?
if you have subscription. you can try ROOMBOOK EXTENSIONS
it will give you an EXCEL compatible schedule of rooms and its internal surface area of walls (less the opening), floors etc.
https://www.youtube.com/watch?v=wPdZdge37hA
and im sure there are alot of alternatives out there..
0 Posts No Rating |
Hi,
Thank you so much, this i actually what I need.
Quantities By Room |
Mon, Dec 29, 2008 at 11:07:32 AM
Fittings assigned to room outside the room area? |
Mon, Nov 19, 2007 at 10:43:47 AM
Revit 2016 Room finish schedule and material schedule |
Thu, Mar 9, 2017 at 3:41:41 PM
schedules by room |
Thu, Dec 15, 2011 at 7:36:58 AM
Glass(daylight) in material-take-off or schedule |
Sat, Jul 13, 2013 at 7:38:02 AM
Members: | 2037276 | Objects: | 23017 | Forum Posts: | 152210 | Job Listings: | 3 |
