24 Users Online (23 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Render materials OK in AutoDesk 360, not rendering in Revit
Tue, Nov 18, 2014 at 12:46:01 PM | Render materials OK in AutoDesk 360, not rendering in Revit
pilkington11
Hello,
I'm working on interior renders and using revit 2015. I've been using AutoDesk 360 to see what my renders generally look like, then render in revit for the final product (I find Revit gives better renders, my company will not pay for AutoDesk credits).
The renders look ok in AutoDesk 360, and when I try to render in Revit, the rendered materials come out blotchy, as if there is a disco ball in the middle of the room, see attached.
Any suggestions?
Mon, Nov 24, 2014 at 3:26:42 PM | Render materials OK in AutoDesk 360, not rendering in Revit
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I haven't done much rendering with 360 but it does look 'material' related. It's not resoving your materials properly. You may also want to apply daylight portals for the view.
Autodesk 360 cloud
Fri, Feb 22, 2013 at 11:21:57 AM
Uploading dwfx to Autodesk 360
Mon, Jun 30, 2014 at 3:50:49 AM
Revit Custom Materials Rendering Objects invisble
Mon, Mar 14, 2011 at 10:42:56 AM
13
Autodesk 360 Rendering - Adjust Exposure Problem
Tue, Mar 26, 2013 at 9:43:22 AM
Revit materials missing at rendering [ 1 2 ]
Tue, Jun 14, 2011 at 11:24:22 PM
22
Page generation time: 2.9575
