111 Users Online (109 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> stairs
Thu, Nov 13, 2014 at 10:07:46 AM | stairs
xpaperleafx
I have a stair that runs up 5 floors.  The riser, etc. set up correctly. The only problem i have is when i exit the drawing mode it creats multiple dashed lines one on top of eachother instead of just seeing one making it look very messy. Does anyone know how to fix this? I've attached a picture.
Thu, Nov 13, 2014 at 10:20:33 AM | stairs
You are in control of visibility.   Under VG/Stairs - experiment with all of the switches for your stairs.   We typically turn off the stairs and railings beyond the view's cut plane.
Wrapping stairs
Thu, Aug 12, 2010 at 5:27:02 PM
Handrails at Curved Stairs
Mon, Sep 1, 2008 at 1:43:04 PM
stairs not dotted above
Fri, Feb 17, 2012 at 1:44:46 PM
Spiral Stairs around a Central Post
Sat, Apr 16, 2011 at 9:27:29 AM
Help with stairs
Fri, May 4, 2018 at 7:32:59 AM
Page generation time: 0.2612
