61 Users Online (58 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Can't create camera or walkthrough on first floor but can on others. Why?
Wed, Nov 12, 2014 at 3:57:26 PM | Can't create camera or walkthrough on first floor but can on others. Why?
ericlovell
I need a camera to be set up on the first floor of a project that we are doing at my office. I have tried moving the camera from the second floor to the first to get it, but when that happens it gets rid of walls and it changes what the floorplan looks like. Is there something that may be adjusted in settings as to why I can't make a camera?  Need help ASAP
Thu, Nov 13, 2014 at 7:13:59 AM | Can't create camera or walkthrough on first floor but can on others. Why?
Why are you moving a camera?   You can have as many camera views as you want.   Simply open the first floor plan and place a new camera there.
Tue, Nov 18, 2014 at 9:48:53 AM | Can't create camera or walkthrough on first floor but can on others. Why?
nathan2
I'm having an issue where I can't create a camera on the first floor.  It simply will not let me click to create the camera.  All other floors work fine.  Am I missing a setting?
Tue, Nov 18, 2014 at 12:40:30 PM | Can't create camera or walkthrough on first floor but can on others. Why?
Are you sure this is a floor plan view?
Simply create a new floor plan under view.   (Hint - Uncheck the do not duplicate box)
Tue, Nov 18, 2014 at 12:48:07 PM | Can't create camera or walkthrough on first floor but can on others. Why?
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
What's the camers height vs the plan's view range and cut plane ??
Tue, Nov 18, 2014 at 2:06:21 PM | Can't create camera or walkthrough on first floor but can on others. Why?
nathan2
Eye level is 5'6", Plan cut Plane is 4'-0", we didn't change the defaults so it's set up like out-of-the-box Revit.  We did get around it by just duplicating the First Floor Plan, but that shouldn't be necessary.  What causes floor plans to lock out the ability to create camera views?
Tue, Nov 18, 2014 at 3:38:41 PM | Can't create camera or walkthrough on first floor but can on others. Why?
Where is the top of your view range?   Camera has to be under that.
Wed, Nov 19, 2014 at 10:32:39 AM | Can't create camera or walkthrough on first floor but can on others. Why?
ericlovell
It was all due to phasing. I know how to edit a camera level and such, but it was all because we have many many many different phases and the phase we were in wasn't the main model with all things and so it wouldn't allow us to do it. Thank you all
Camera Settings for a Walkthrough animation
Tue, Dec 4, 2018 at 12:04:26 AM
Revit 9.1 walkthrough resets camera path and active camera
Thu, Jul 19, 2007 at 11:19:33 AM
Editing Walkthrough Cameras field of view (FOV) in Plan View
Fri, Jun 26, 2009 at 1:17:38 PM
Revit Walkthrough; between key frames
Thu, Jul 30, 2015 at 8:22:01 AM
Cameras into a walkthrough
Fri, Apr 3, 2015 at 1:20:27 PM
Page generation time: 1.1219
