111 Users Online (110 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> How to create doors on a curtain wall ??
Wed, Jun 30, 2004 at 7:36:37 AM | How to create doors on a curtain wall ??
menghwee
Wed, Jun 30, 2004 at 5:44:42 PM | RE: How to create doors on a curtain wall ??
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Curtain wall doors cannot be placed the same as normal doors in a wall. You must load a specially created curtain wall door. Once loaded, select the PANEL (not the wall, by using the tab key) then go to the properties and change the type from system panel to the door you just loaded... Regards, Chris.
Thu, Jul 1, 2004 at 3:26:52 AM | RE: How to create doors on a curtain wall ??
menghwee
Regards,
Chris.ThanKA A mILLION
Curtain wall doors
Mon, May 4, 2009 at 2:05:34 AM
Curtain wall doors wont center up
Mon, Oct 12, 2009 at 4:28:48 PM
No curtain wall doors on curtain walls!
Sun, Nov 22, 2009 at 7:10:58 PM
tagging curtain wall doors
Mon, Jul 30, 2007 at 3:14:11 PM
Curtain windows/doors
Fri, Dec 12, 2008 at 6:59:44 AM
Page generation time: 4.4986
