61 Users Online (60 Members):
Forums >> Revit Systems >> Technical Support >> Domestic Water Re-circulation System?
Has anyone created one in their model with all pipes connected? I am assuming we still cannot connect multiple system type pipes together in Revit?
0 Posts No Rating |
You can connect multiple system, just edit/create a new the family. The only downside is the system type will be "Undefined". We do this when we connect our condensate pipe on the storm pipe also on the bypass pipe for the hydronic supply & return on the boiler room.
Thanks. I did dabble with the out of the box generic tee fitting and changed the connections to the appropriately named type (HW and HWReturn). That worked but it seems like I had to follow an order of operations in connecting it all so the whole line didnt turn to one sytem or the other completly. Maybe I am doing it the most current way possible at the moment....
hot water recirculationg from domestic hot water system |
Mon, Jun 14, 2010 at 2:17:05 PM
Domestic Hot water - No flow |
Fri, Dec 11, 2009 at 3:50:05 PM
Specific piping systems in Revit MEP |
Wed, Sep 30, 2009 at 11:26:09 AM
Plumbing system identity |
Mon, May 2, 2016 at 10:38:00 AM
Hi Press & Lo Press Dom Cold Water |
Wed, Nov 11, 2009 at 9:19:49 AM
Members: | 2042216 | Objects: | 23026 | Forum Posts: | 152216 | Job Listings: | 3 |
