68 Users Online (66 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Tips & Tricks >> 76 Autodesk Revit Tips And Shortcuts
Tue, Nov 11, 2014 at 5:21:13 PM | 76 Autodesk Revit Tips And Shortcuts
viatechnik
Hi,
Here are a list of tips and shorcuts to make Revit easier and more productive.
Anything you disagree with or feel we left out? Let me know!
http://www.viatechnik.com/76-autodesk-revit-tips-shortcuts/
Fri, Nov 14, 2014 at 12:17:07 PM | 76 Autodesk Revit Tips And Shortcuts
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
This is 'barely ok' at best for someone who has never used REIVT, but VERY general, very non detail tips and in some cases incorrect. Calling some of them tips is a stretch. It also says "76 Tips" as the title ?? It's more like 23 peices of information and 53 suggested Keyboard Shortcuts (some of which I would not suggest). I think you trying to use each keyboard shortcut as it's own tip is stretching it a little : )
Below is a sample of a EXTREMELY weak, incorrect and Horribly worded tip that basically says 'Use the View Range' tool but does nothing to actually show you how View Range works and it also fails to mention the Plan Region override It'also for the most part is incorrect. When things dissappear from the model view (what ever that is) chances are it's NOT the view range. You don't even mention the fact that view range only applies to plan views. And ceiling Plans work differently from floor plans. At the very least you should change the words "disappearing from the modelling view" with "not being cut in a plan view".
Here's your idea of a tip:
"If your views are now displaying parts of a model, or models created are disappearing from the modelling view, it is most likely because it is outside of your specified “View Range”. To fix this, simply go to the Project Properties an adjusting the View Range to a more wider range". weak weak weak.
On a scale of 1 to 10 on tips I'd give this an overall 1.78
Unfortunatly these types of misleading headlines are becoming far to commonplace these days and even worse it's becoming acceptable.
Edited on: Fri, Nov 14, 2014 at 12:19:51 PM
Keyboard Shortcuts Won't Open/Show
Tue, Feb 26, 2013 at 11:09:04 AM
Keybord shortcuts for individual user logon?
Tue, May 1, 2007 at 11:23:56 AM
Debug Menu- Keyboard shortcuts
Tue, May 20, 2008 at 10:03:40 AM
Some Keyboard shortcuts not working?
Tue, May 5, 2009 at 2:52:55 PM
help on rendering revit models in Autodesk VIZ
Sat, Jun 4, 2011 at 8:19:56 PM
Page generation time: 2.1871
