48 Users Online (47 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Region/Hatch Printing Problems
Tue, Nov 11, 2014 at 3:04:26 PM | Region/Hatch Printing Problems
KraigZ
I have a series of Hatched Regions around parts of my plan in color depicting different things. In order to see components through these hatches I set the transparency to at least 50 throughout. I havnt had any problems until recently I went to print & none of my transparancies on one sheet will print. Any idea what is causing this or better yet, how to fix this?
Thanks,
KraigZ
Tue, Nov 11, 2014 at 3:11:51 PM | Region/Hatch Printing Problems
We can't help much.
You need to make sure your settings are the same for each plot to the same plot driver setup and your hatch patterns are set the same as you indicate.  Double check....
In addition - print preview doesn't mean anything anymore.
Wed, Nov 12, 2014 at 2:55:46 PM | Region/Hatch Printing Problems
KraigZ
It is only happening in that one view port though. It happens in Print preview, and when I print. I have even tried to delete the view and place it on a new sheet, and I got the same result. Even my key on that sheet, which is referenced by another view port, is turning out right. Any Ideas? I need help fast
Wed, Nov 12, 2014 at 3:10:03 PM | Region/Hatch Printing Problems
KraigZ
I fixed my own problem, but thank you if you tried. If anyone has this problem again, here is how I fixed it. In the sheet, click the desired viewport, in the properties, select Graphic Display Options, and change the Style to Hidden Lines. See Attached Picture for Clearification.
Wed, Nov 12, 2014 at 3:38:26 PM | Region/Hatch Printing Problems
So the views were not the same.....
There are so many variables that problems like this are hard for us to track down.   I now recall people having similar issues because their view was not hidden lines.
Thanks for reposting.
Adjusting the hatch pattern inside of a filled region?
Fri, Dec 5, 2008 at 11:07:41 PM
3-d hatch region
Mon, Aug 11, 2008 at 10:32:34 AM
Plan Region not shwoing wall hatch??
Mon, Jan 14, 2008 at 12:03:30 PM
Transparency when printing
Fri, Jun 19, 2015 at 1:33:46 PM
hatch pattern not printing
Mon, May 8, 2017 at 12:56:52 PM
Page generation time: 0.9063
