63 Users Online (61 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Have Topography, need it in CAD
Tue, Nov 11, 2014 at 2:17:10 PM | Have Topography, need it in CAD
poblivion
Revit 2015 (and if I knew what I know now, would have done it in 2014)
Have a complex project with 5 options and 5 different topo surfaces that need to go to the model maker.
PROBLEM:  They don't have 2015, only 2014 Cryingthanks for the continuing uncompatibility Revit!!!)  SO whet I have needs to be imported to CAD  (in what format??????) and I've been told the following:
1)needs to match up with existing insert,
2) contours must be continuous and pass through buildings,
3) "roads" (the subregions denoting paved areas on site) must be continuous polylines.
Now, I've tried to export ONLY the toposurface and that was not working for me.  Does ANYONE have a solution as to HOW to import this?????  I'm afraid I'll be here until the end of the weekend (It's TUESDAY) connecting the dots in CAD because the topolines don't seem to be importing continuously.
Tue, Nov 11, 2014 at 2:47:45 PM | Have Topography, need it in CAD
poblivion
HA!!!
Guess I've stumped the experts in this place.
Wed, Nov 12, 2014 at 8:24:59 AM | Have Topography, need it in CAD
poblivion
Thanks for the help.
Wed, Nov 12, 2014 at 9:27:13 AM | Have Topography, need it in CAD
We always tell users that they must think ahead and confirm Revit release with all of their consultants prior to starting a project.  If these people have a legit Revit license, they should be able to install 2015.   Even if they don't. they can install and use as a viewer.  Obviously, you can export CAD files anyway including a siteplan with contours.
View linked CAD file on top of Topography
Mon, Nov 19, 2012 at 10:52:17 PM
matching contour lines from civil CAD when creating Topography (2019)
Fri, Dec 4, 2020 at 2:09:47 PM
Revit Topography doesnt follow CAD import
Wed, May 25, 2011 at 11:38:27 AM
Creating a topography from 3D CAD survey import
Thu, Feb 23, 2012 at 7:53:02 AM
sloped Topography
Sun, Oct 22, 2006 at 9:57:26 AM
Page generation time: 3.5971
