71 Users Online (69 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Room tag
Tue, Nov 11, 2014 at 1:12:30 PM | Room tag
Jozko
Hallo, i have problem with room tags in floor plan 2 plan its ok, but  i want tag 1. floor plan write error to me : None of the created elements are visible in Floor Plan: 1.NP_skutkovy stav View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings.In schedule i see this rooms... :/ but i need tag on floor plan.Ty for help.
Tue, Nov 11, 2014 at 1:13:59 PM | Room tag
Look in VG / Annotations - Turn on room tags.
Tue, Nov 11, 2014 at 1:20:21 PM | Room tag
Jozko
i have turn on room tags in visibility settings... but nothing :/
Tue, Nov 11, 2014 at 1:32:26 PM | Room tag
Possibly I don't understand your question but I don't think so.  You got an error message which means to me that the room is there and on.
To tag a room in a view, the rooms must be on, the room tag category must be on.  If you can pick the room, then you can tag it.  If you can't pick the room, then the room is not on or it is not cut by the view cut plane.   You can't tag a room above or below the view cut plane.
Tue, Nov 11, 2014 at 3:08:29 PM | Room tag
ivanzidong
Is the workset correct?
Room tag not showing in only one room. [ 1 2 ]
Sun, Apr 6, 2025 at 9:54:40 AM
24
Editing a room tag
Thu, Oct 12, 2017 at 3:17:42 PM
Using Room Tag Family Parameters in a Celing Tag Family
Mon, Sep 22, 2008 at 7:52:41 AM
Room Tag Leaders
Thu, Oct 21, 2021 at 9:45:57 AM
ROOM TAG TAGS ONLY HALF OF THE ROOM
Wed, May 6, 2015 at 8:58:22 AM
Page generation time: 0.4225
