42 Users Online (41 Members):
Forums >> Revit Building >> Technical Support >> Export all properties BYLAYER, and create new layers for overrides.
Ive been working on a export setup from Revit to DWG to match my companies CAD standards. This is not easy, but im making slow progress. I wanted more control over layers so I decided to export all properties BYLAYER, and create new layers for ovverides. I like this because I can change the outline color of a column without messing with the hatch. (for example it names Concrete-elevation, concrete-elevation 1, etc..). I dont want to haveto change these colors and line weights in CAD everytime. How can I modify the newly created layes that the export creates before its actully exported? Is this possible?
Thanks
I believe it's all there in the Export > Options (very bottom) under the application pull down.
Export to DWG creating color overrides in text families |
Tue, Feb 10, 2015 at 8:27:00 AM
Layers mapping for DWG export |
Thu, Jun 18, 2015 at 11:55:54 PM
Grid line problem (cad export) |
Wed, Apr 11, 2012 at 7:18:20 AM
renaming the export settings |
Fri, May 7, 2010 at 8:51:02 AM
Turning off Layers when Exporting to Cad |
Wed, Nov 5, 2008 at 6:06:36 PM
Members: | 2017233 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
