125 Users Online (123 Members):
Forums >> Revit Building >> Technical Support >> Phase filter "Show Complete" - why can't i create a copy? Solutions?
![5 Stars: 4 Votes](/images/stars_5.gif) |
I have 2 questions:
1 - I would like to create a phase filter that is similar to show complete (hides the demolished elements). When I try that, and i have exactly the same settings as the show complete, it shows the demolished elements. How can I solve that?
2 - I need to have 2 versions of show complete to colour the previous phase in a separaet set of drawngs. Is there another way to colour phases? I could not find the parameter "phase created" under under the view filters. I tried that approach. Or is is possible to filter with that parameter?
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
I don't see any way to do this with phase filters. But you can add a project parameter to your elements and assign a property that will allow you to use a normal filter.
New opening cut showing in Existing elevation with [show complete] filter |
Fri, Sep 12, 2014 at 4:21:24 AM
Phase Filter - Can't change from "Show All", Greyed out |
Mon, Sep 24, 2012 at 1:17:42 PM
Can't filter "Phase Created" in MTO for linked Revit files? |
Mon, May 12, 2014 at 7:01:45 AM
phase filters and lineweights |
Fri, May 22, 2009 at 3:15:11 PM
Maintaining "Phase Demolished" properties. |
Thu, Jun 18, 2015 at 8:19:39 AM
Members: | 2017060 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
