171 Users Online (170 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> New Stair Tag Family!
Tue, Nov 11, 2014 at 1:49:00 AM | New Stair Tag Family!
anubhav1237
Hi. I need tips on this. Attached is a image of staircase drawing highlighting (Tread, width and Riser) of staircase. I wanted to create this tag family with labels in such a way that all these three are linked to staircase properties. So for any other staircase I could use the same Tagging and would just have inserts the values. Please help and and earliest reply could be appreciated. Thanks.
Tue, Nov 11, 2014 at 7:07:53 AM | New Stair Tag Family!
Start with a generic tag, then set the category to stair run and then you will see these options for labels when you add them to the tag.
Thu, Nov 13, 2014 at 1:20:07 AM | New Stair Tag Family!
anubhav1237
Thanks a lot! It worked. I had to place prefix and sufix with some spaces to adjust the alignment and it worked out well. Smile
Can not swap out one stair family for another
Thu, Sep 19, 2013 at 12:24:20 PM
2013 stair path symbol for component stairs displays differently
Thu, Feb 6, 2014 at 3:03:51 PM
Stair tag
Sun, Oct 30, 2005 at 3:36:25 PM
Using Room Tag Family Parameters in a Celing Tag Family
Mon, Sep 22, 2008 at 7:52:41 AM
Up/Down Tag in stairs
Fri, Jan 9, 2009 at 6:59:02 AM
Page generation time: 1.0278
