105 Users Online (104 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Family editing help!
Mon, Nov 10, 2014 at 11:03:40 PM | Family editing help!
anubhav1237
Hi. I have recently started learning and working on Revit.
I am stuck and need help! I am attaching a family file for Concrete beam which has 48mm size grooves on both sides.  I want to change the size of the groove from 48mm to 50mm (keeping the beam size same as 400mm). Can anyone explain how can I do this? I think this might have been done using sweep command or something but not sure. An earliest reply would be appreciated.
Thanks
Anubhav
Tue, Nov 11, 2014 at 1:13:19 AM | Family editing help!
ronmalit
5 Stars: 3 Votes
yes it is a solid sweep with profile
what you need to do is to look for the profile in the project browser (under FAMILIES> PROFILES) and right click EDIT.
it will open the profile in another window for you to change 48 to 50
Tue, Nov 11, 2014 at 1:49:41 AM | Family editing help!
anubhav1237
Thanks! it worked!
Help editing All in one Revit Content families
Mon, Dec 21, 2015 at 1:27:25 PM
HELP WITH EDITING FAMILY
Mon, Oct 22, 2018 at 8:05:02 AM
Problem editing a family
Wed, Dec 29, 2010 at 10:20:34 AM
Trouble editing an existing family Window
Wed, Nov 23, 2011 at 2:40:38 AM
Editing a family created by a company
Fri, Feb 14, 2014 at 9:23:18 AM
Page generation time: 1.4538
