56 Users Online (55 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Outlet Visibility Above Cut Plane
Wed, Nov 5, 2014 at 11:03:02 AM | Outlet Visibility Above Cut Plane
a1997xf211
We are documenting wall eelctrical outlets in a fitness center.  The outlets occur above the cut plan, so they do not appear on the floor plan.  Does anyone know a simple way (not plan region, as this requires too much management) to accomplish this?
Wed, Nov 5, 2014 at 11:14:33 AM | Outlet Visibility Above Cut Plane
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Edit the family and have symbolic lines that can sit below the actual family.
Wed, Nov 5, 2014 at 11:17:02 AM | Outlet Visibility Above Cut Plane
If the outlet family has a vertical invisible line that is added to it that is long enough to be cut by your view cut plane, then the outlet will show.   << I really don't like this process but it will work.
I don't understand why you don't want your view cut plane to be set hight enough to see these outlets.  Think in reverse - add a large plan region to bring the rest of the view back down if you have to.
Outlet families
Tue, Jul 17, 2007 at 11:49:41 AM
Controlling window visibility
Tue, May 12, 2009 at 12:49:40 AM
Cut Plane display issue
Tue, Oct 11, 2011 at 12:48:43 PM
Problems with visibility of Header and door openings
Fri, Jul 26, 2013 at 11:05:24 AM
How to control where the cut plane is for families?
Sun, Nov 22, 2009 at 10:20:00 AM
Page generation time: 0.9699
