36 Users Online (35 Members):
Forums >> Revit Building >> Technical Support >> Curved roof tiles into gutter.
![Jamie351 Avatar](user_avatar/249546.jpg)
![4 Stars: 7 Votes](/images/stars_4.gif) |
hey guys is there a way to show part of the roof structure (tiles) curved into the gutter?
Revit 2018........ |
bump :\
![3.5 Stars: 4 Votes](/images/stars_3.5.gif) |
do the roof tile layer as a separate roof maybe, with sufficient overhang to sit between front and back of gutter.
pick a relevant section view after making, select the new tile roof and move vertically to suit.
like two roofs? that probably cause other issues down the track though.
think of it not as 2 roofs , but 2 layers.
first roof would be the rafter plane
second would be the tile thickness.
gap between the tile batten space.
in a section you would insert some tile battens ( detail lines maybe) in the gap
between the 2 roof "layers".
just one way of acheiving what you want.
yeah true. Thanks for the help will have to give it a go.
You could try using the cut profile tool under the veiw tool.
3D Roof Tiles for temple |
Sat, May 15, 2010 at 6:55:41 AM
Gutter display on roof plan |
Mon, Jun 11, 2007 at 3:47:21 PM
tiles 3d on the roof |
Fri, Feb 23, 2018 at 10:45:21 PM
ROOF TILES |
Fri, Feb 23, 2018 at 10:52:53 PM
How do i make roof tiles appear in elevations an sections? |
Tue, Sep 27, 2005 at 6:47:20 PM
Members: | 2019203 | Objects: | 22958 | Forum Posts: | 152184 | Job Listings: | 3 |
