46 Users Online (45 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> floor slab hosted families - on sloped slabs
Thu, Oct 30, 2014 at 1:59:22 AM | floor slab hosted families - on sloped slabs
Feargt
Hi,
I have not been able to find an answer to this but perhaps someone here could help give a definitive answer.
I need to create a pump sump family but I need it to have it so that if the floor slab that will host the family is sloped then the top of the walls of the sump adjust accordingly to the slope of the foor slab. The sump itself should remain vertical with a defined depth from the centre of the sump opening.
Similarly I am having the same issue with a concrete base for a pump. the top of the concrete base should remain horizontal but the bottom should adjust accordingly to the slope of the floor slab.
if any further info required just ask.
What do I need to do to achieve this functionality?
any help appreciated.
thanks
Thu, Oct 30, 2014 at 9:01:21 AM | floor slab hosted families - on sloped slabs
OK.... This was a fun challange.  I'm not sure I would have done this as a family.  I think it would be far easier to do this with walls, floor and a void family to cut the walls and all of that grouped together but I did it as a family to see if it could be done.
Below are the proof images that it works.  But there are severe limitations to this.
  1. The family has to be modified to have the correct floor thickness in the family.
  2. The family has to be 'square' with the slope of the floor
  3. The family has to be rotated correctly to match the floor slope
I have included the family too but it is pure junk.  I only include it so you might study it to start thinking about the process.
  • The solids are NOT parametric.
  • I used a void to cut the slab hole and the sump hole....again - not parametric.
  • I used another void to cut the sump sides off at the bottom of the slab.   not parametric except for the angle
  • You can not rotate a reference plane so I used a reference line with an instance parameter to control the angle of the void cut.   You have to measure the bottom angle of the sab and enter that data in the family properties.
So... fun to see what happens but I would recommend not doing this.  Try creating as I said above.  Once grouped, the group can be placed then ungrouped to make adjestments.  Groups can be saved to your library.
Thu, Oct 30, 2014 at 9:05:00 AM | floor slab hosted families - on sloped slabs
Oops - here is the junk family....
Thu, Oct 30, 2014 at 9:56:39 PM | floor slab hosted families - on sloped slabs
ronmalit
5 Stars: 3 Votes
hi feargt
my suggestion is pretty straight forward:
just create any parametric family you would require. see attached family from WWHub. making it fully parametric.
I just added the OFFSET parameter from the face.
after loading the family to ur sloped slab... you dont need to calculate or know the ANGLE, SLAB THICKNESS or CORRECT ORIENTATION..
just offset it abit inside the slab (eat-in inside the slab)  and use JOIN command to finish it of.
ty
** dont be mad, i dont have much... i am homeless
Fri, Oct 31, 2014 at 12:58:09 AM | floor slab hosted families - on sloped slabs
Feargt
thanks for suggestions WWHub and ronmalit, I knew there had to be some workarounds that I could use. I will look at both in more detail over the weekend to see which is most suited and most beneficial for me. But i have plenty of food for thought there. Thanks
Creating drop panels to the underside of a sloped floor slab
Fri, Feb 12, 2016 at 9:41:01 AM
Floor Hosted Families on a Sloped Floor
Wed, Jun 4, 2008 at 7:31:21 AM
Flooring and Cladding Families
Wed, Jan 18, 2006 at 5:38:35 PM
new slabs, existing slabs, and the nature of constraint(s)
Wed, Dec 11, 2013 at 12:21:24 PM
Concrete Slabs with compound angles???
Wed, Feb 4, 2009 at 11:28:45 AM
Page generation time: 1.1082
