50 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> hatch patterns with shading - reflected ceiling layouts
Wed, Oct 29, 2014 at 3:21:42 AM | hatch patterns with shading - reflected ceiling layouts
geraldrogers
I would like to be able to show which ceiling areas in an office refit are new by shading them a particular colour. However I would also like to be able to show the specific grids which relate to the tile sizes at the same time. Is there a way to both shade and show the ceiling grid? I can't work one out other than adding a annotated filled region over the top. Can hatch patterns be created that also have a shaded background colour?
Gerald Rogers
Revit 2015
Wed, Oct 29, 2014 at 8:12:41 AM | hatch patterns with shading - reflected ceiling layouts
See 1st image:
Set your view to shaded - create a material with a shaded color - see second image
For colored grid - over-ride graphics in view - see 3rd image
Fri, Oct 31, 2014 at 6:59:09 AM | hatch patterns with shading - reflected ceiling layouts
geraldrogers
It seems that there was a problem with the material I created for the ceiling. I had previously duplicated the generic Revit ceiling tile and changed the hatch pattern to what I required. However with this material even when you change the colour in the material pallette it doesn't alter in any of the views (see attached). I can't work out why. So when I made a new material for the ceiling, gave it a colour and a hatch, voila! It worked.
Gerald Rogers
Revit 2015
WALL HATCH PATTERNS IN REFLECTED CEILNG PLANS 2009
Fri, Aug 29, 2008 at 10:01:32 AM
Floor/Wall tile layouts
Fri, Oct 7, 2005 at 2:17:30 AM
I need a simple hatch pattern for a waffle ceiling
Fri, Jan 18, 2008 at 12:53:45 AM
Hatch patterns
Tue, Jan 3, 2012 at 2:30:16 PM
Custom Hatch Patterns
Thu, Dec 23, 2004 at 3:00:33 PM
Page generation time: 1.4806
