124 Users Online (123 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> Revit interior walls transmission area calculation
Tue, Oct 28, 2014 at 1:44:23 PM | Revit interior walls transmission area calculation
kamalakannan
Hi,
I have few doubts in Revit. While doing Heat load calculation using Revit. It’s not taking interior walls transmission area calculation that means around the condition walls like middle room’s walls. I am doing one project heat load calculation using Revit and HAP. While comparing both only I am facing this issue only. Rest of other all areas peak cooling load is matching with HAP calculation. So any have idea about this issue.
Thanks,
KAMALAKANNAN
Does instance parameter considered in quantity calculation of walls?
Thu, May 23, 2019 at 2:04:24 AM
room area calculation
Thu, Jan 15, 2009 at 5:51:20 AM
Sound Transmission Evaluation of Assemblies
Wed, Jul 18, 2007 at 11:35:32 AM
Area calculation with dormer
Mon, Dec 6, 2010 at 8:43:26 AM
Can I make ''Area'' colors opaque to dwg that exists underneath the area plan?
Fri, Nov 22, 2019 at 12:27:55 PM
Page generation time: 2.7078
