42 Users Online (40 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> need a help about render
Sun, Oct 26, 2014 at 4:58:00 AM | need a help about render
leahdudu
good day
i've alittle issue when i used to render (interior render) all the data inside show by grey colour even it had a nother colour over family
what should i do?
plzz any help ......
u can see attached below for my render.
Mon, Oct 27, 2014 at 3:25:44 PM | need a help about render
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
You probably need more interior lighting or a portal. Interior renderings require lots of light. Also you can dramatically alter the brightness and contrast etc after the render is done using the Image > Adjust Exposure dialog box. See attachment.
Mon, Oct 27, 2014 at 3:28:31 PM | need a help about render
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Not enough information.  This could be a phasing issue, but most likely you don't have your materials applied to the families correctly.
Tue, Oct 28, 2014 at 6:26:57 AM | need a help about render
HKicsak
I think it's definitely the materials, not the lighting. I used to have renderings look like that in 3ds Max if it could no longer find the materials (wasn't mapped right, I had deleted the material, etc.). If all of the furniture is families that you downloaded, you may not have the materials it is looking for. Edit the family to use materials from the Autodesk library.
Tue, Oct 28, 2014 at 9:14:36 AM | need a help about render
leahdudu
thanks you guys
i guess the issue is the material
but i download these families from here
and i cant edit the material there
Sad
Tue, Oct 28, 2014 at 9:17:30 AM | need a help about render
You can assign any material you want.
Are these families with CAD imports?   If so, then you assign materials by layer.
Tue, Oct 28, 2014 at 9:21:13 AM | need a help about render
leahdudu
No WWHub  i import them as RFA. form Sad
Tue, Oct 28, 2014 at 9:29:36 AM | need a help about render
Then just change the materials...
First understand that if a family has uniquely named materials and has been loaded into a project, then THE PROJECT RULES!  The materials are now set in the project and you must change them there or delete the family and all of the materials from the project then change them in the family and reload/place the family in the project.
Open the family - each element is assigned a material -
Tue, Oct 28, 2014 at 9:31:08 AM | need a help about render
leahdudu
WWHub you are right
but some families are like a group shall i explode them & assign a new material for them or not?
Tue, Oct 28, 2014 at 9:32:38 AM | need a help about render
No need to explode any groups....
Perhaps you should show us the family ... or post it.
Also - always say what Revit.
Tue, Oct 28, 2014 at 9:36:12 AM | need a help about render
#11
leahdudu
Sir WWHub i used to download this sofa (u can check it throw this link below)
http://www.revitcity.com/downloads.php?action=view&object_id=14290
and also am work with revit 2015.
Tue, Oct 28, 2014 at 9:57:49 AM | need a help about render
#12
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Just so you know this is a CAD file imported into a Revit family.  You need to fix the materials in the family itself.  As you can see from my images you are missing the image files for the materials.
Wed, Oct 29, 2014 at 8:08:14 AM | need a help about render
#13
leahdudu
teafoe5 you are right
thanks alot u helped me enough.
Render goes ok but when i change angle - the render is black
Tue, Oct 20, 2015 at 4:38:11 AM
Revit render or 3ds max design render?
Sun, Jan 4, 2015 at 10:19:29 AM
RENDER NOT HAPPENING...
Tue, Sep 20, 2005 at 5:00:45 AM
render masterplan
Sun, Jul 31, 2011 at 1:14:53 AM
I"M HAVING DIFFICULTY CHANGING THE RENDER COLOUR OF MY BALUSTER/STAIRCASE
Wed, Jan 19, 2011 at 4:52:18 PM
14
Page generation time: 0.3159
