83 Users Online (82 Members):
Forums >> Revit Building >> Technical Support >> Column taking on adjacent fill patterns
5 Posts No Rating |
I am wrapping a concrete column with other walls. The column takes on the fill pattern of adjacent walls when one or two of the walls are aligned with the face of the column. The columns' properties remain unchanged, and the column sometimes returns to its native hatch when the walls are moved from the face of the column.
Attched is a photo showing two identical columns with wraps. The walls were copied from the upper column and tightened up around the lower column. The columns are linked from a Revit Structural file. Both version are Revit 2015.
Any help is appreciated. Thanks!
Jonathan
5 Posts No Rating |
Slight correction: The columns are architectral and part of the model.
That is what architectural columns do.... consider them to be more like a pilaster.
From your HELP:
Architectural columns inherit the material of other elements to which they are joined. Compound layers in walls wrap at architectural columns. This does not apply to structural columns.
5 Posts No Rating |
Hey Thanks! That's helpful.
Jonathan
5 Posts No Rating |
Jonathan
Perpsective Fill Patterns |
Mon, May 10, 2010 at 6:12:50 PM
Fill Patterns |
Mon, Mar 10, 2008 at 6:40:09 AM
create/ convert hatch patterns (.pat) to revit fill patterns |
Tue, Jun 2, 2015 at 11:29:00 AM
Fill patterns, where are they? |
Tue, Mar 31, 2009 at 10:11:29 AM
Wall Fill Pattern question |
Tue, Oct 23, 2012 at 8:39:37 AM
Members: | 2022294 | Objects: | 22973 | Forum Posts: | 152200 | Job Listings: | 3 |
