62 Users Online (61 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> What is the best way to Add a custom mass object to your project
Mon, Oct 20, 2014 at 5:47:05 PM | What is the best way to Add a custom mass object to your project
yushi
So I was going to make a custom sitting place around a concrete wall in my project. I tired making an In-place mass which at first was
going well. But then When I add other walls which interferes with the in-place mass, it rotates. I thought maybe I should make the sitting place a family and insert it. But then I need walls and floors of my project to build the sitting around them.
I attached a screenshot.
Any idea what is the best aproach to this?
As I said at this stage which you see on the picture, everything is alright but when I want to add walls near the sitting place, it reacts and rotates.
thanks
Tue, Oct 21, 2014 at 7:13:46 AM | What is the best way to Add a custom mass object to your project
DON'T USE MASS!!!!
Do an in-place family in the correct category.  That's what that tool is for.
adding mass in family editor or in place family creation
Thu, Nov 23, 2006 at 9:52:53 AM
Making an object from solid mass...
Mon, Oct 25, 2010 at 7:17:07 AM
Problem with loading mass with pattern in a Project
Tue, Jul 7, 2015 at 9:30:04 AM
Conceptual Mass Project Space Visibility
Fri, Jul 15, 2011 at 1:46:12 PM
Unable to load conceptual mass into project
Fri, Sep 11, 2015 at 1:40:27 PM
Page generation time: 1.6171
