68 Users Online (67 Members):
Forums >> Community >> Newbies >> DOT NOT SEE LEADERS
8 Posts No Rating |
This just started happening. While placing text (with a leader) i do not dymanically see the leader until after I type in the text and hit enter. Whats up with that?
I never see a leader before I do the text and add one it. This is how Revit works. I'm not sure how you saw one before
I always see the leader while I click the points. REVIT 2014 and 2015 tested. Something has changed. I'm not running 2015 R2.
What release are you running? I am on 2015 update release 4 and the leader goes in and then I add the text and it works fine
I'd also test this out with an 'out of the box' project template file just in case it's file specific.
Can leaders and dimensions be modified |
Mon, Dec 22, 2008 at 11:02:52 AM
Howdy! I'm new! |
Wed, Apr 14, 2010 at 1:29:56 PM
Leaders moving_Annoying |
Fri, Jan 20, 2012 at 7:37:30 AM
display edges and openings above the cutting plane in a dash dot dot linestyle |
Thu, Mar 10, 2005 at 7:12:05 PM
Dimension with Tick and Dot |
Fri, May 21, 2010 at 10:36:20 AM
Members: | 2022290 | Objects: | 22973 | Forum Posts: | 152200 | Job Listings: | 3 |
