70 Users Online (69 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Revit 2015 error: "A fatal error has occurred..."
Wed, Oct 15, 2014 at 1:46:03 AM | Revit 2015 error: "A fatal error has occurred..."
AngeloDK
Hi everyone.
I'm doing a school project in Revit 2015 using the Central File system. It's been working flawlessly up until last week, where I suddenly starts getting this error:
"A fatal error has occurred. The application will be terminated. You have the opportunity to save recovery files for all you changed projects.
Would you like to save a recovery file?"
My group member has no issues working in the file, but every time I Save, Load, Sync., or anything like that, I get the error.
I tried Googling for answers. Some had suggested updating my graphic card drivers, however they are all up to date. I also tried uninstalling Revit and installing it again, with no change.
I've tried quickly making a new project with a few walls etc., making it a Central File, making a local file and then make changes. This happens without any issues. This makes me think it should be the original Central File that's the issue, right?
I'm working on a Windows 8.1 machine.
Does anyone have any suggestiones at all?
Thank you in advance.
/Sebastian
Thu, Oct 16, 2014 at 11:01:49 AM | Revit 2015 error: "A fatal error has occurred..."
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Sounds like a potential CAD file issue. Rename the linked CAD files so they can't be found when the project loads up. If the problem goes away then you need to do some maintenence on the CAD file.
Fatal error on a shared job Revit 2015
Tue, Mar 15, 2016 at 1:06:32 AM
Revit Fatal Error
Tue, Jan 12, 2010 at 10:35:50 AM
Fatal error, Now cannot open revit!
Sun, Jan 11, 2009 at 12:16:03 PM
Print Error "Display Error"
Tue, Dec 20, 2005 at 5:04:34 PM
" an unknown error occurred while accessing ....central.rvt"
Wed, Oct 11, 2017 at 12:53:21 AM
Page generation time: 2.1801
