63 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> adding room number to window schedule
Tue, Oct 14, 2014 at 4:37:40 PM | adding room number to window schedule
ledgewood33
I would like to add a column to the window schedule that shows the room number the window associates with. I was able to place a column in the schedule that is titled room number but it doesnt populate the fields in that column. I think there has to be a parameter setup for that and thats where I am stuck.
Wed, Oct 15, 2014 at 7:33:42 AM | adding room number to window schedule
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Open your window family (plan view) and put a check mark next to Room Calculation Point in Properties. You can select the green arrows and flip the orientation From/To if needed. Load the family to your project. Make sure you have the correct field in your window schedule - From Room/To Room to match the settings in the family.
Wed, Oct 15, 2014 at 9:42:13 AM | adding room number to window schedule
ledgewood33
I followed your steps. I dont see anything populated in the two new columns (from room or to room) I think I am missing a step
Wed, Oct 15, 2014 at 10:55:45 AM | adding room number to window schedule
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Flipping the green arrows should populate one field or the other (see pics). I’m not sure why it is not working for you. Can you upload your project or at least provide some screen shots?
Wed, Oct 15, 2014 at 11:05:06 AM | adding room number to window schedule
ledgewood33
apparently its just this one project. a co-worker tried it on his project and it worked. thank you for the info
Bookend Room Schedule with Room Number
Mon, Apr 18, 2016 at 10:54:10 AM
Embedded window schedule in Room schedule
Thu, Nov 19, 2015 at 1:03:50 AM
How to associate window to a room in window schedule
Fri, Oct 1, 2010 at 10:32:13 AM
Adding Room Number to Door Tag
Sun, Jun 23, 2013 at 9:14:47 AM
Window Schedule
Fri, Mar 31, 2017 at 8:08:39 AM
Page generation time: 1.7936
