134 Users Online (132 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Slab Rebate Query
Tue, Oct 14, 2014 at 1:21:17 AM | Slab Rebate Query
rdavies1973
rdavies1973 Avatar
Hi all
I'm trying to figure out how to create a slab rebate into a concrete floor.
i.e. I am using brick veneer construction where the outer brick and air gap sit below the timber frame.
Is there a tool to do this? I know there is a tool to ADD slab edges ... but I want to CUT the concrete. In the past I have created a full depth slab for the middle ... then built a thinner slab for the rebate. I then go into section and use fills/join geometry etc to tidy up.
This is a very popular method of construction in Australia so would like to know if there are any better ideas out there.
Rhys
Tue, Oct 14, 2014 at 8:09:45 AM | Slab Rebate Query
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I don't know what a slab "rebate" is.  Is it just a thickened edge?  If so just use that tool and if your slab and the thickened edge are the same material they will appear to be joined
Wed, Oct 15, 2014 at 4:40:07 AM | Slab Rebate Query
rdavies1973
rdavies1973 Avatar
Hi teafoe
I've attached an image to help illustrate the issue.
There are two images ... the image on the left shows the slab rebate (cut into the slab).
It's popular in Australia and New Zealand.
Wed, Oct 15, 2014 at 8:50:40 AM | Slab Rebate Query
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I would create that using the thickend slab edge and give it that profile.
Foundation walls / vs slab edge sweeps
Wed, Nov 8, 2006 at 6:10:43 PM
Line Based Wall Rebate Family Question ?
Fri, Mar 28, 2014 at 1:18:48 PM
stair query
Tue, Aug 25, 2009 at 11:59:43 AM
Lighting Placement Query - Revit Architecture 2009
Tue, Mar 24, 2009 at 7:49:52 AM
query with elevation details
Mon, Dec 1, 2008 at 5:12:35 AM
Page generation time: 0.3211
