55 Users Online (54 Members):
Forums >> Revit Building >> Technical Support >> revit 2014 - One particular view crashes revit
I have a roof view, pretty simple view, but when I double click it the Project Browser, the view starts to switch, but then I get the spinning wheel and revit hangs and I have to force quit.
This is a working view, so I can delete it except for one thing. I have floor plan callouts on this view. If I delete the view, how do I get those floor plan callouts to show up on another roof plan?
Thanks for your help-
Soo, I can't delete that view. It deletes the other views. grrrr. anyone have any ideas why this one view crashes Revit?
Did you audit your file?
Yes, I audited it a few times.
Be careful if you are using dependent views....
It sound like you will have to create a new plan and callouts. You can open the new callouts and copy paste/ same place from the old callouts to the new one. Then delete your plan and all the callouts.
Do you get any sort of Revit error window? We have experienced a few crashes related with the graphic card, so I would suggest updating the graphic card drives and make sure you are using the latest Revit 2014 update.
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
Nope, no error. It just locks up with a blank view, some menu items are still there in the ribbon.
Try to open the project in another PC to see if you get the same problem. That may give you a clue.
Revit 2014 Update 2 crashes constantly on Nvidia Quadro FX 3800 cards [ 1 2 ] |
Sun, Sep 20, 2015 at 11:28:23 PM
17
Revit crash when dimensioning |
Wed, Feb 12, 2014 at 9:28:22 AM
Revit crashes when placing keynote legend |
Tue, Jul 25, 2017 at 2:07:43 PM
Revit 2014 Issue- Dragging Views Into Sheets & System Crashes |
Wed, Apr 27, 2016 at 5:47:08 PM
Exporting RPC content from Revit 2014 to Max 2014 |
Tue, Aug 19, 2014 at 10:26:21 AM
Members: | 2017227 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
