29 Users Online (27 Members):
Forums >> General Discussion >> Revit Project Management >> Tagging Wainscott and Wall above
0 Posts No Rating |
On my main level floor plan, I would like to tag both the 3' tall wainscott and the rest of the wall that goes up to the roof. Currently only the top wall tags and I cannot tab through to select the wainscott below. My view range goes down to 0' off of main level so I know the wainscott is technically visible. I have a dummy tag that I use to show stacked wall tags but I would prefer to tag the walls with true annotation tags that update if the type mark were to change.
Thanks for any help
![3.5 Stars: 393 Votes](/images/stars_3.5.gif) |
Change your cutplane temporarily so that it cuts this wall then tag it. I can't remember if the tag will stay when you move the plane back up.
0 Posts No Rating |
Excellent idea, I have been moving around the building and hiding the walls above temporarily and tagging the wainscott. Thank you
Tagging a Copy/Monitored Wall |
Wed, Jun 22, 2016 at 4:06:50 PM
Problems tagging wainscottting wall sweeps |
Wed, Jun 20, 2012 at 2:34:37 PM
Tagging items based on view |
Wed, May 9, 2012 at 3:01:54 PM
Tagging Graphical Column Schedule |
Wed, Nov 24, 2010 at 8:41:14 PM
tagging a curtain wall |
Tue, Nov 9, 2010 at 2:10:00 PM
Members: | 2026106 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
