109 Users Online (108 Members):
Forums >> Revit Building >> Technical Support >> Ramp and Topo surface problem Revit 2014
30 Posts No Rating |
Hi everyone...I'm using Revit 2014
I'm trying to create a ramp with possible landings on sloped topo surface but can't get the ramp to cut into the surface and show as such. I searched the forums but couldnt' find anything exactly.
See attached picture...the ramp is outlined.
Any help is greatly appreciated.
Nothing cuts a topo surface except for topagraphy tools like a pad or grading.
If this is a site ramp on grade, then maype you should just grade the topography, split the surface to define the ramp and then apply a material to the split area. Read this in your HELP:
http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-CE895A23-9BF3-479B-B750-360F27AB825B
Thanks WWHub...I'll give it a try...I know that stairs sort of cut into the topo and I need to show retaining walls at some areas.
How to infill a topo hole from plit surface |
Fri, Jun 15, 2012 at 9:54:54 AM
Topo Surface from autocad into revit |
Tue, Oct 13, 2009 at 10:37:25 PM
PLEASE HELP! ROTATING AN ELEMENT ON A RAMP (Revit 2014) |
Wed, Jul 9, 2014 at 2:43:28 PM
Surface pattern to Topo surface |
Mon, Aug 19, 2013 at 10:50:10 PM
A ramp! |
Thu, Jan 21, 2016 at 11:37:45 AM
Members: | 2056382 | Objects: | 23069 | Forum Posts: | 152325 | Job Listings: | 3 |
